2002 Dodge Stratus new heads
10,200 MILES • 6 CYL • 2WD • AUTOMATIC
LANA JARVIS
i put in a oil sending unit then oil pump then a timing chain then a serpertine belt then new heads then car wouldnt start i was told the starter went out put in a new starter then my mechanic told me the motor locked up and he could fix it for 100 in o=parts plus labor Im scared and broke
Jun 14, 2010 at 4:29 PM
RACEFAN966
  • 5,029 POSTS
Can you turn the engine over manually? Have you pulled the starter and taken it to your local parts store to have it tested to find out if it is a bad one or not?
Jun 16, 2010 at 3:47 AM
LANA JARVIS
put on a new starter said engine locked picked up car and returned money for starter, so now i wonder did he put stsrter on
Jun 16, 2010 at 12:17 PM
RACEFAN966
  • 5,029 POSTS
Ok so you didn't answer the question if the engine will turn over manually or by hand? Meaning put a socket on the crank shaft bolt and use a wrench to see if the engine will turn over.
Jun 17, 2010 at 3:40 AM
RACEFAN966
  • 5,029 POSTS
Also did you put the head gaskets on correctly? If not there may be water in the cylinders and this would stop the engine from turning too. To find out pull the spark plugs and see if the engine turns over.
Jun 17, 2010 at 3:42 AM
LANA JARVIS
a wench was used and turned over but wouldn't saty running the new mech. said the damage was internal and would cost me to check it out he said to junk it.
Jun 18, 2010 at 10:31 AM
RACEFAN966
  • 5,029 POSTS
Ok to junk it is up to you but after new heads I think something is just being missed. Now if the car will not turn over with the starter then I would like you to check for power at the S term on the start with key in start position. Let me know what you find and we will go from there.
Jun 19, 2010 at 2:00 AM
