1997 Dodge Stratus need help
DRUFFIN
Interior problem
1997 Dodge Stratus Front Wheel Drive Automatic
i installed a new radio with a screen in it and i went to hook up the dvd player which is seperate and when i did it blew my interior lights as well as my door locks and the radio wont come on either i did check the radio fuze and it was fine can u help i checked all the fuzes as well why wont it work?
Jan 18, 2010 at 1:26 PM
CARADIODOC
  • 34,414 POSTS
You connected the radio's ground wire to the dash light wire. Very common mistake because the low resistance makes it check like a ground wire. There is no ground wire in the two connectors. That's why there was a braided ground strap bolted to the original radio, or it had a black ground wire clipped to the radio.
There are two fuses for the radio. The station preset and clock memory fuse will be tied into a different circuit that is always hot such as the horn or interior lights.
caradiodoc
Jan 23, 2010 at 4:55 AM
