Power Steering High Pressure Line
1996 DODGE STRATUS
TRAIN104MAN
How Do i Change a High Pressure Power Steering Line on 96 Dodge Stratus ie. What do i need to take off to get to the connection going to the power steering pump.
Dec 6, 2009 at 1:02 AM
CARADIODOC
  • 34,381 POSTS
Are you prepared to tear your hair out?
First you get the car on a hoist, then remove the bar that bolts on under the radiator and the engine cross member.
Here's where it gets fun. You must unscrew the power steering hose's brass fitting on the front of the rack and pinion assembly, driver's side. To gain access to it, you must lower the cross member. To lower the cross member, you have to unscrew the high pressure power steering hose from the rack and pinion assembly, driver's side because that hose is so short, it won't allow the cross member to drop more than about an inch. You can't get to the fitting unless you lower the cross member, . . . see the problem yet?
One fellow coworker had the bright idea to cut the old hose so he could drop the cross member. Worked slick, but how do you get the new hose on? The secret, as I found out later, is to remove the left front tire, and possibly a plastic splash shield, (I can't remember), then use a flare-nut crow's foot wrench, a universal joint, a ratchet extension, another universal joint, another extension, then a ratchet. Fish them up to the brass fitting on the rack. I changed dozens of these nightmares on cars new enough to be under warranty so nothing was rusty yet. Hopefully you will be able to unscrew the nut by hand once it is loose.
There is a 10mm nut holding the hose bracket under the left rear side of the engine valve cover. Can't remember for sure, but I think that comes off from on top, not from under the car. Drop the cross member, then reach up from underneath to unscrew the brass nut from the bottom of the power steering pump. The metal part of the hose does not just go straight down, that would be way too simple. It comes down a few inches, curves forward a few inches, curves up a few inches, then goes over the top of the pump shaft, behind the pulley. You will need to have all other attaching points loose, then you must wind the hose to, in effect, unscrew it from around the pump shaft.
Put the new hose on the pump first, then reverse the order to install it. There was a service bulletin about replacing these hoses for a complaint of transmitting power steering pump buzzing noise into the passenger compartment. That's why, as the alignment tech, I replaced so many. Warranty paid 3.5 hours to do the job, but with much experience, it always took me at least four hours. That's with a hoist and all the right tools at hand. I would never attempt this job while lying on the floor.
There was also a bulletin for replacing the rack and pinion assembly for making a very slight chirp just as you started to return the wheel after cornering. Both of these problems were so minor, no one would bother with demanding repairs if they had to pay the bill themselves. But since it was covered under warranty, demanding customers demanded it must be fixed.
Look very closely at the orientation of that bar between the cross member and the radiator. I had a habit of reinstalling it incorrectly on the cross member, over the top or underneath; I can't remember, but I do know it was a lot of unnecessary work to take it off again to install it the right way.
caradiodoc
Dec 8, 2009 at 7:41 PM
JAMES HOFFMAN
Well. I don't know about HAVE to use a hoist but. I just replaced the high pressure line on my 1996 dodge stratus using just 1 jack stand on each side of the car. Penetrating oil was the key to loosening the collar at the rack, from there you have to loosen the brake line clamp against the fender well and move it ever so gently out of the way to reach behind and in with your wrench. I admit it was slow going but not impossible. It did help though that I had replaced the power steering cooling lines with transmission cooling line hoses so that made it much easier as well. All in all I only swore a few times and cramped up once...lol
Oct 3, 2019 at 2:46 AM
  • 55,423 POSTS
Excellent addition to this thread! Please feel free to help out whenever you are on the site :)
Oct 3, 2019 at 6:04 AM
