my car bogs down if you try to drive it normally. if you do not pat the gas very lightly it will flood out after bogging down. it also cuts off for no reason no matter whether i am stopping or taking off or driving down the road or idling. also the oil light is on along with the engine light and battery light. yet the oil is full and the oil pump is working. occasionally the air bag light stays on after cranking, when it does nothing electronic such as windows, blinkers, vents, etc. works until i turn off and restart the car. we have replaced the spark plugs 4 times in the last year, replaced the egr valve and the temp. control sensor and the intake gaskets and battery. each time we replaced something the car ran good for a few days then right back where we started. what could the problem be? we are running out of money to dump into this car.
Mar 16, 2009 at 6:23 PM
