crankshaft pulley
GOFASTER
i have a 1993 dodge stealth w/89,000 miles. i have had a lot of squealing when i turn on my air conditioning, but one day my crankshaft pulley separated. I ordered a new pulley, but my question is, Do i just remove that one bolt on the crankshaft to replace the pulley or do i need to look for something else? I have a 3.0 sohc engine.
Aug 26, 2007 at 5:51 AM
P_67_K
[quote:7e5ebd8458="gofaster"]i have a 1993 dodge stealth w/89,000 miles. i have had a lot of squealing when i turn on my air conditioning, but one day my crankshaft pulley separated. I ordered a new pulley, but my question is, Do i just remove that one bolt on the crankshaft to replace the pulley or do i need to look for something else? I have a 3.0 sohc engine.[/quote:7e5ebd8458]
I have a 1991 Dodge Stealth R/T Twin Turbo AWD AWS. (3.0 DOHC) I had to change my pully it was jagged and eating away my belt. I was able to change mine by just that bolt. It may be hard at first but if you use a breaker bar and some muscle it should come off. You'll also find as you crank on the bolt your engine truns to so... Hope I could help you in time!
Oct 22, 2007 at 4:05 AM
