While driving the car shifting into 5th gear remains with non-contact. (like the car is in neutral). The shifter remains in the 5th gear position. All other gears work properly. Rumor has it that i can remove the rear trans cover and should see a bolt loose, which, if tightned properly. would re-engage 5th gear. Does that particular senerio apply to my situation?
Jan 7, 2009 at 11:27 AM
