Front wheel bearings
DODGE SPRINTER
RB FRENCH
I Have a 2003 Dodge sprinter 2500 with 48K miles and I'm replacing the brakes and want to repack the front wheel bearings. I was easily able to remove the outer bearing, but I'm not sure how the inner bearing is removed. Do I need a press or a special tool?
Thanks
Mar 5, 2007 at 10:02 AM
BUBBA_KOSKI
  • 129 POSTS
not to take off, the only time you need a press is when packing the rotor (plenty of grease) just be careful not to strip the spindle
Mar 7, 2007 at 8:25 AM
RETIREDAUTO
  • 46 POSTS
it's probably the grease seal holding the bearing in,you must pry out and repl. the seal after you repack the bearings,i am not familiar w/ a sprinter??, but call local auto parts store and see if seal is available first,if so heres how tou cheat. w/ outer bearing removed and rotor still on spindle,re install nut(only) several turns(till spindle is flush w/ end of nut). then pull rotor outward,sliding on spindle w/a quick motion. nut should catch inner bearing and knock out seal. thats the easiest way i can explain it. good luck let me know how it works out for you..
Mar 8, 2007 at 9:59 AM
