1991 Dodge Spirit Fluctuating Tempature Guage....
1991 DODGE SPIRIT
YOUWILLLOVEMEGZ
Engine Cooling problem
1991 Dodge Spirit 4 cyl Front Wheel Drive Automatic
When I take off in the morning my car temperature gauge gets very hot to the point where my check gauges light comes on. Once I stop or let off the gas my temperature will go back down to normal and stay normal. I have put in a new thermostat, temperature sensor, radiator, and checked to make sure my fan is working properly. Everything is doing okay. There is plenty of coolant. What else could it be?
Jul 11, 2010 at 2:17 AM
  • 31,937 POSTS
I would be checking that you have bleed all the air from the system, and i would consider re checking for a faulty new thermostat,
mark (mhpautos)
Jul 11, 2010 at 2:37 AM
HELLLP ME
I have the same problem did you fix it i cant figure it out
Nov 19, 2010 at 6:54 PM
YOUWILLLOVEMEGZ
It's still fluctuating but not trying to overheat as often as it was. Not loosing coolant either. I have found that letting my car run for 10 minutes before I leave has helped somewhat.
Nov 20, 2010 at 5:17 PM
  • 31,937 POSTS
did you replace the thermostat yet?
Nov 20, 2010 at 5:56 PM
YOUWILLLOVEMEGZ
Yes, twice.
Nov 21, 2010 at 2:53 PM
