heat n a/c doesn't come out of the dash vents is it a vacum hose or the switchs are bad or something other then that
Dec 6, 2008 at 1:53 PM
Repair Safety Notice:
This information is for general instructional purposes only. Vehicle repair can be dangerous.
Verify all information, follow manufacturer service procedures, use proper tools and safety equipment,
and consult a qualified repair shop when needed.
CAR REPAIR CONTRIBUTOR
Hi:
It could be one or the other. The best thing to do is start at the engine and work your way through the firewall. Check all vacuum lines. There will be a hissing noise if you find the leak. If all lines are good, then move to the switch.
