1988 Dodge Ramcharger Erratic Speedometer
1988 DODGE RAMCHARGER
160,000 MILES • V8 • 2WD • AUTOMATIC
88DODGED150
At speeds over 25 mph, the speedometer needle begins to bounce erratically. The faster I go the more erratic it becomes - until I get down below 25 mph. There is also a lot of noise that seems to be coming vrom the rear of the instrument panel.
Feb 11, 2009 at 10:01 AM
DAVE H
  • 13,384 POSTS
check or replace the speedometer cable
SPEEDOMETER
NOTE:Disconnect negative battery cable before performing repairs to instrument panel.
Ram Pickups & Ramcharger
Remove cluster faceplate and cluster assembly. Remove cluster mask lens. Remove speedometer retaining screws. Disconnect speedometer cable. Remove speedometer. To install, reverse removal procedure.
Feb 11, 2009 at 10:06 PM
88DODGED150
[quote:f081239a71="Dave H"]check or replace the speedometer cable
SPEEDOMETER
Remove cluster faceplate and cluster assembly. Remove cluster mask lens. Remove speedometer retaining screws. Disconnect speedometer cable. Remove speedometer. To install, reverse removal procedure.[/quote:f081239a71]
I just wanted to confirm that I am replacing the speedometer cable not the actual speedometer.
Thanks
Feb 12, 2009 at 2:23 AM
DAVE H
  • 13,384 POSTS
because you can hear a noise behind the cluster .. you will need to check the cable and fixings at the rear of the instrument cluster ..
Feb 12, 2009 at 1:34 PM
