Intermittent sputtering
JAZZPLAYER
  • DODGE RAM
I have a 1994 Dodge Ram 1500; 190,784 miles; 5.2 engine. 2 months ago it stopped. It sputtered (oil light came on and off), then went dead. The crankshaft sensor was replaced. It started again, but still had the sputtering but not as much. About 1 month later the sputtering has gotten worse. Took to a diagnostic shop and after repairing a "intake leak", then said it was the computer. I replaced the computer and it still sputters. While driving it will "jerk" and feels like rough idle and almost die, but doesnt. No one seems to know what the problem is. Also the tune up was done as well. Any help in this area would be greatly appreciated. Thanks.
Tuesday, August 7th, 2007 AT 8:31 PM
DPWD23
  • 136 POSTS
Doing research on this one.
If anyone else has any ideas on it, feel free to jump in.
Wednesday, August 8th, 2007 AT 12:00 AM
DPWD23
  • 136 POSTS
You need to check the fuel pressure. You could have a plugged line, or a pump that's not putting out enough pressure.
If the fuel pressure is fine, it could be a clogged injector.
You said a tune up was done, did they check the timing?
Friday, August 10th, 2007 AT 6:00 PM
