1988 Dodge Ram Oil in Brake Lines
AKITADISIGNS
Dodge Ram 150 1988 170000 mi
resently we were informed that there was oil found in our break lines mixed in with the break fluid. my question is how long would the oil need to be in there inorder for there to be enough damage to cause compleat break failur? we had recently had the truck in to have the oil changed
Apr 6, 2007 at 10:42 AM
  • 75,988 POSTS
[quote:b5f62b2a2e="akitadisigns"]Dodge Ram 150 1988 170000 mi
resently we were informed that there was oil found in our break lines mixed in with the break fluid. my question is how long would the oil need to be in there inorder for there to be enough damage to cause compleat break failur? we had recently had the truck in to have the oil changed[/quote:b5f62b2a2e]
Bleed the entire system out till it clears and put fresh correct type fluid and rebleed the whole system again to get that air out.
Apr 8, 2007 at 1:51 AM
Suggested Repair
Bleed the entire brake system until the fluid runs clear, refill with the correct brake fluid, and bleed the system again to remove air.
Conversation Summary
The owner of a 1988 Dodge Ram 150 reported oil mixed with brake fluid in the brake lines and asked how long that contamination would take to cause complete brake failure, noting a recent oil change. The expert advised bleeding the system until clear, installing fresh correct fluid, and bleeding again to remove air.
