1999 Dodge Ram Serpentine Belt Screech
HAWGSTRUCK
I began to hear screeching in my engine with occasional clicking at random times. I thought the screeching was the belt and replaced it because it showed signs of wear. However, the same sounds are still there. There is no leak from the water pump and the A/C does not seem to be the problem because the sounds continue when all air is off. I noticed that the serpentine belt seems to oscillate as it passes the water pump pulley (moving left and right on the pulley). I can't tell if the shaft the pully is on is bent or if there is something else wrong with it. Could this be the source of the problem? What do I do?
Mar 12, 2006 at 8:38 AM
RAYHUT
  • 134 POSTS
you should try and use some belt dressing that can stop the sqreeching.
Mar 12, 2006 at 7:54 PM
XJETMECH
  • 12 POSTS
The screeching could be caused by a week belt tensioner.
If the clicking is really slight, there may be nothing wrong. On some belts, there is a backing on the outside at the splice. This can make a small noise as it goes across the idler.
Mar 15, 2006 at 7:45 AM
WESMUR
  • 6 POSTS
could be one of the pulley bearing is going bad. take off the belt and check the bearing of each pulley by spinning them by hand then hold the pulley firmly in one hand and check for side play by moving the top and bottom in and out alternately . i have seen many bad bearings after 70,000 miles.
Aug 11, 2008 at 1:30 AM
Suggested Repair
Remove the serpentine belt and spin each pulley by hand, checking for rough bearings and side-to-side play. Also inspect the belt tensioner for weakness. Belt dressing may temporarily reduce screeching, and a slight click can be normal from the belt splice backing on the idler.
Conversation Summary
A 1999 Dodge Ram owner reported engine screeching and occasional clicking that continued after replacing a worn serpentine belt. There was no water pump leak, the noise continued with the A/C off, and the belt oscillated side to side on the water pump pulley. Replies suggested a weak tensioner, a possible normal splice noise, belt dressing for the screech, and checking each pulley bearing for roughness and side play with the belt removed.
