2002 Dodge Ram computor code
69,000 MILES • V8 • 2WD • AUTOMATIC
GARYPATTISON
Hooked up to Auto Zone tester, check engine light was on. Reading was as follows: PO6O1,internal control,module memory,check sum error. they didn't know what this meant and suggested I ask you. I replaced the front control module that was attached to the power distribution center. That fixed what was wrong but now the check engine light comes on periodically. It doesn't stay on all the time but when it comes on it's not blinking.
thankyou
Nov 6, 2009 at 10:51 AM
  • 110,248 POSTS
Have you had the computer again to see if the code has changed?
Nov 6, 2009 at 3:54 PM
GARYPATTISON
[quote:9869623653="garypattison"]Electrical problem
2002 Dodge Ram V8 Two Wheel Drive Automatic 69000 miles
thankyou[/quote:9869623653]
Nov 9, 2009 at 11:31 AM
  • 110,248 POSTS
If it is still coming on, there may be a simple explaination for it. Have you had it scanned since?
Nov 9, 2009 at 11:33 AM
GARYPATTISON
I have not had it scanned. Who can do that? Now the check engine light has gone out! Will it reset itself? I don't drive this truck very often, only when I pull my trailer.
Gary
Nov 9, 2009 at 12:30 PM
  • 110,248 POSTS
Most nationally recgnized parts stores will scan it for free. However, if it is off, stays off, and is running good, let it go.
Nov 10, 2009 at 6:26 AM
