I have no reverse
LARRY SANDERS
  • 2001 DODGE RAM
  • V8
  • 4WD
  • 105,000 MILES
After getting stuck in the snow, and making a few unsuccessful attemps to get unstuck, I stopped the truck and got pulled out. Now I have no reverse, I did for awhile but I had to rev the engine up a little to get it to move. Everything else is allright, no slippage or anything. The fluid level is okay, and the fluid is not burnt. Also, I did not hear anything break.I'm lost?
Wednesday, February 17th, 2010 AT 11:21 AM
JALEX19100
Does it slam into reverse when you rev it up or just not want to go until you give it fuel? When I bought my pickup it wouldn't engage into reverse until I accelerated and then it (somewhat violently) engaged and reversed quickly. It was hard to back up just an inch. I replaced the transmission fluid, filter and adjusted the rear and front kick-down bands with an in-lb torque wrench and that took care of it. The fluid and the transmission pan looked neglected and took a while to clean. I am not sure if the right transmission fluid was even in there! I saw an empty quart of Mercon under the seat that made me extremely nervous.
Saturday, May 1st, 2021 AT 6:36 PM
