2001 Dodge Ram airconditioningwontcool
114,000 MILES • V8 • 4WD • AUTOMATIC
BADBRAD49
rechargedwhenipulledfreonlineoffaircond.lineallthefreonleakedoutfromfittingdoineedtoreplaceline
Jun 17, 2009 at 2:01 PM
  • 31,937 POSTS
Hi there,
that was a bit hard to read,
You will have to replace the O ring seals at least, the system will have to be vacuumed down and it must hold a vacuum (this proves no leaks in the system) then the correct volume of refrigerant can be added, this should be done by a tech as to little or to much refrigerant will cause problems.
Mark (mhpautos)
Jun 17, 2009 at 2:07 PM
