2001 Dodge Ram V8 Four Wheel Drive Automatic
The truck was making a lot of noise from the rear end before I parked it. Now it won't move backward in two wheel drive but will in four. When I went to move it the first time I was going to back up and heard noises coming from the rear end. I looked under the truck while in reverse and noticed the drive shaft would move but truck wouldn't. I also noticed there was gear lube leaking from the pinion seal. What could the problem be specifically.
Thursday, February 18th, 2010 AT 11:25 AM
