engine starts fine- but during during "mid-point" of warm up, it will stall if left to idle?
22,000 MILES • V8 • 4WD • AUTOMATIC
HOTPEPPERS227
  • 7 POSTS
After warm-up, all is well. The problem is hardly noticeable if you drive forward for the entire warm-up. No codes from scanner.
Jul 15, 2009 at 3:46 AM
  • 110,248 POSTS
Can you descrbe what is happening? When it happens, how often, under what conditions...
Jul 20, 2009 at 4:26 AM
HOTPEPPERS227
  • 7 POSTS
The engine starts fine- but during during "mid-point" of warm up, it will stall if left to idle. It will run in "park" OK, but will stall when placed in reverse. If left alone for about 10 minutes, the problem goes away, and the truck runs fine for the rest of day. After warm-up, all is well. The problem is hardly noticeable if you drive forward for the entire warm-up. No codes from scanner. New plugs, wires, cap/rotor, IAC, intake air temp, clean throttle body. The situation is very predictable, run 10 minutes, stall for 10, then OK. Very similar problem to other Dodge on your Web. Did not replace O sensors, (2).
Jul 20, 2009 at 5:51 AM
  • 110,248 POSTS
I would think that an O2 sensor would have set the computer / check engine light. Have you ever had the fuel pressure tested from a cold start through warm up?
Jul 20, 2009 at 1:33 PM
HOTPEPPERS227
  • 7 POSTS
Fuel pressure good thru entire range. The truck usually carries a camper, thus the low miles. It sits idle for weeks during off season. (A clue perhaps) Is it possible for a sensor to "freeze" ?? Will probably go to dealer for overnight soon.
Jul 21, 2009 at 1:46 AM
  • 110,248 POSTS
If it sits or extended periods, I would check to make sure the EGR is working and not sticking. Also, make sure no mice have eaten through any wiring or vacuum lines.
Jul 21, 2009 at 6:58 AM
HOTPEPPERS227
  • 7 POSTS
Final Disposition -- The nose on the starter broke off and flew around, hit the crankshaft position sensor and bent it out of position. New sensor and starter--ALL IS WELL !!
Aug 12, 2009 at 1:56 AM
  • 110,248 POSTS
That doesn't happen often. REgardless, I'm glad it's fixed.
Aug 12, 2009 at 4:04 AM
