2000 Dodge Ram backfire/stutter
SAUERKRAUTANDY
  • 2000 DODGE RAM
  • V8
  • 4WD
  • 86,000 MILES
My ram will once in a while stutter and sometimes backfire causing it to almost stall out, mainly when the truck isnt up to temp, if you give it some gas it goes away and once its warmed up its usually fine, I was thinking fuel filter but since its in the tank id like to try some other things first, mabye a throttle posiotion sensor, or mabye an egr valve? What do you think?
Friday, October 29th, 2010 AT 6:41 AM
  • 109,747 POSTS
Have you ever nocticed smoke from the exhaust? As far as the sensors, they should set thec check engine light
Friday, October 29th, 2010 AT 8:12 AM
SAUERKRAUTANDY
No smoke, what were you thinking mabye a valve? The engine is quiet when running
Friday, October 29th, 2010 AT 8:30 AM
  • 109,747 POSTS
Valve, headgasket. Have you checked for vacuum leaks and the EGR? Often times a backfire will be caused by a vacuum leak.
Friday, October 29th, 2010 AT 10:42 AM
