Turn Signals Cut off after a couple of blink
NANDO_RAM_1500
  • 1999 DODGE RAM
  • V8
  • 174,000 MILES
My turn signal work SOMETIMES, and when they do they cut off after a couple of blinks. I dont think its the bulbs or the fuse. I was wondering if is the Multi Control lever. And if it is how much will the repair cost?
Monday, March 9th, 2009 AT 9:31 PM
BLUELIGHTNIN6
  • 16,542 POSTS
I would inspect the flasher before venturing into the switch itself. Do the hazards act the same way as the turn signals? The flasher is located in the seating area, driver side, at the left side of instrument panel on fuse block. When you say they "cut off" do you mean that the switch goes back to its original position or the lights just stop flashing? If the switch moves back then it is probably the switch faulty but if they stop flashing with switch still in place then I would definitely inspect the flasher first.
Thanks for using 2CarPros. Com!
Tuesday, March 10th, 2009 AT 12:42 AM
CLINTG437
I am having the same problem with my 2001 Ram 3500. The switch remains in the same position, but the lights just stop flashing after a few times (depending on how it acts). I've changed the flasher unit about 3 times now and I've even changed the switch itself (located on the steering column). My emergency flashers work fine, but they run through another flasher. All bulbs have been changed.
Did changing the flasher work for you or did you have to do something else? At this stage, I'm thinking something dealing with one of the computers.
Wednesday, April 22nd, 2009 AT 8:46 PM
CARADIODOC
  • 33,916 POSTS
There's different flashers depending on how many lights it has to run. Dodge trucks also came with a heavy duty flasher in the glove box, from the factory, for use when pulling a trailer. Some of the heavy duty flashers are not affected by adding more lights.
In the standard duty flasher, there's a heating element across the contacts. Current flow through the element AND the bulbs causes the element to heat up. The element is wrapped around a bimetallic strip which is the arm of one of the contacts. As it heats, it bends, makes contact, and full current flows to the bulbs. The contacts bypass the heating element so it cools until the contacts, and the lights, turn off. Then the process starts all over. Because of this design, the instant you turn the signals on, the lights will be OFF for a second or two, then they will start to blink. If a bulb is burned out, less current flows so it takes longer to warm up the heating element. This is why they blink very slowly or not at all. Anything that adds resistance, (pitted contacts, corroded wire or connector, burned out bulb, etc.) Reduces the flash rate.
In the heavy duty flasher, the contacts are on when it is at rest, (as opposed the standard flasher which is off at rest). The heating element is in series with the contacts rather than across the contacts. The instant this unit is turned on, the lights will also be on. As the element warms up, the lights will blink off. The open contacts stop current flow so the element cools and starts over. These flashers are less susceptible to a burned out bulb; they just take a little longer to start flashing.
When the signals do not flash at all, or stop flashing due to insufficient current flow, the lights will stay on if you have a heavy duty flasher; they will stay off with a standard flasher.
As a quick test, try switching the two flashers in your truck. The hazard flasher is designed for six to eight bulbs, so it might flash a little slow because there are only three or four bulbs per side, but it should work. If you continually burn out flashers, check for damaged wires in a trailer connector. Also, NAPA has an electronic flasher with a small relay inside. Not sure what their thinking was, but I found two of them in a truck in a junk yard.
Caradiodoc
Saturday, April 25th, 2009 AT 3:57 AM
