1999 Dodge Ram rough idle
OZBURNA1
  • 1999 DODGE RAM
  • V8
  • 172,000 MILES
Changed idle control sensor and idle is still rough sometimes cutting off the engine
Monday, October 18th, 2010 AT 11:34 AM
WRENCHTECH
  • 20,761 POSTS
Check for vacuum leaks. Pull the EGR valve off and see if it is seated closed all the way with no carbon holding it open.
Monday, October 18th, 2010 AT 12:20 PM
MENDOZA__
  • 20 POSTS
My dodge ram 1500 had the same issue. I tried checking for vaccum leaks but found none. Just in case that does not work you can check the idler control module. Remove it and clean it out, it is located or connected to the throttle body. Hope this helps.
Thursday, October 28th, 2010 AT 4:07 PM
WRENCHTECH
  • 20,761 POSTS
Please start another question of your own. We can't address more than one car in the same question.
Thursday, October 28th, 2010 AT 4:50 PM
