Is there a fuse or a fusable link for the Code reader port? Code reader does not power when plugged in. Code reader itself odes work.
Sep 26, 2010 at 12:07 PM
JDL
✓Experienced Mechanic
Pin 16 of your datalink connector is voltage, hot all the time. That circuit is fuse protected,fuse 12-- 10 amp. Also, my info shows you may be able to access mil codes, doesn't hurt to try. You cycle the key, no crank, on--off, on--off, on, then the mil starts flashing, you count the flashes to get the codes.
