I removed and installed an instrument cluster, speedometer and guages, from my pick-up.I reconnected the PRNDL cable on the position arm on the steering column. When I move the shift lever to the park position on the PRNDL indicator, the pointer moves and displaces in the opposite direction. How do I correct the problem?How do I route the PRNDL cable around the steering column?I'm not sure I routed it correctly.
SPONSORED LINKS
Thursday, August 12th, 2010 AT 5:28 PM
