1999 Dodge Ram 99 dodge ram
180,000 MILES • V8 • 2WD • AUTOMATIC
RRENDO89
i went low on gas, i apparently thought i just had about half a tank in the gas tank but maybe i saw wrong. However, now my truck is empty and my truck won't start. I put about 7 gallons of gas in it because the gas light was on. Didn't change truck still won't start. But gas light turned off. Now the ABS light is on. I might have cranked the truck to many times, maybe thats why it won't start. I also put fuel and carbourater injection flued in it. still not working however it still turns on. What do i do?
Aug 14, 2010 at 2:19 PM
  • 110,248 POSTS
My concern is that you either plugged the fuel filter or burned up the pump. I need you to check fuel pump pressure.
Here is a how to for checking.
https://www.2carpros.com/how_to/how_to_check_fuel_pressure.htm
You will need a gauge, but most parts stores will lend you one. The pressure should be between 44 and 54 psi.
Let me know what you find.
Aug 14, 2010 at 4:12 PM
