1998 Dodge Ram Four Wheel Drive Automatic
I have a 1998 Dodge 4x4 with a 5.2 l motor and around 135000 miles. I have heard many many stories of the tranny going out on these trucks and feel somewhat confident that this is what has happened here. It started with it slipping at highway speed in overdrive or dropping into 3rd irratically. I kept driving it until one day it just lost drive power and came to a stop. I towed it home and let it sit for a month or so then restarted it (to keep seals lubed). It actually moved again, maybe 25 ft then I put it into reverse backed up 5 ft and it then stopped. I tried forward and it would roll on flat ground at 4500 rpm but not enough to pull itself over a small bump. I can't afford to to just take it to a tranny guy and write him a check and would like to just buy a used a tranny and replace it but i'm scared it may be a computer issue or clutch issue instead. Can you help diagnose this. Thank You.
SPONSORED LINKS
Monday, August 9th, 2010 AT 11:03 PM
