1998 Dodge Ram
215,000 MILES • V8 • 2WD • AUTOMATIC
CHARLES 70
when I start my truck up the idle seems rough and when I start driveing it it sometimes makes a popping noise that comes from the engine .I have never checked the timing,and I have changed a lot of sensors.Thee is no check engine light that comes on.I was wondering if the idle air control; valve might have something to do with it.Thanks again chuck
May 19, 2010 at 10:58 PM
  • 31,937 POSTS
Hi there,
I would do a comp test just to eliminate any compression problem, check all vacuum hoses and i would also do the scan as you do not always get a check light with all codes.
mark (mhpautos)
May 19, 2010 at 11:36 PM
