my 97 doge 318 runs good but skips under a pull at around 3000 rpm. i have already chamged plugs wires cap and button and the ecm. the code it gives is clyinder #8 missfire. when we ran the compression test #8 shot gas out to the fender. this happened before the ecm was replaced. it also gives the code of emission system incorrect flow detected everynow an then. what could my problem be? when gas is pressed harder such as going up a hill, the vacuum supply for the inside vents is taken away but comes back when throttle is settled back down.
Apr 7, 2010 at 1:16 PM
