1997 Dodge Ram Reacurring leak/stain on Fuel Tank
JOSHUABUILD
1997 Dodge Ram V8 Four Wheel Drive Automatic
I was under my truck just giving a monthly once over and I noticed a unknown liquid covering the right side of the tank. It appears to be traveling down the tank and towards the front of the vehicle and it has no real smell or odor and appears to be greenish in color. The origin of the leak or spill starts at the top of the tank and out of view. I don't seam to have any fuel related issues concerning performance. (at the point). It starts fine, idles fine, it chugs a little bit up steep grades.
Links to pictures below. Tanks for any advice in advance. JB.
http://picasaweb.google.com/lh/photo/7GG97Is1hDzu0IHL9h8e8A?feat=directlink
http://picasaweb.google.com/lh/photo/sUi2CbezMhJGgyGJp15zNQ?feat=directlink
http://picasaweb.google.com/lh/photo/VnlwBg70nR96sP5X-6KQzA?feat=directlink
Mar 22, 2009 at 7:02 AM
BILLYMAC
  • 2,204 POSTS
on top of the tank their is a seal where the sender installs in tank.... there are a few lines there with orings one of these things have failed. lower tank to find out
Mar 29, 2009 at 2:16 AM
JOSHUABUILD
Thank you for your input, but I think I found the problem. (although I'm going to look at the tank seals as a precaution) It appears as though there is lubricant leaking from where the drive shaft meets the rear axle gear hub. The spinning of the shaft was throwing the oil/lube onto the gas tank. I noticed a leak just right now in my drive way and it's directly under (and coming off of) the drive shaft.
Again thanks for all your help!
Mar 29, 2009 at 3:32 AM
