1996 Dodge Ram control arm bushings
KISTNAX
Suspension problem
1996 Dodge Ram 6 cyl Two Wheel Drive
I have a dodge ram 2500 that has a squeeking noise coming from front end, thinking it is upper control arm bushings? could this be right and are these hard to change
Feb 23, 2009 at 10:35 AM
  • 110,248 POSTS
Hi:
It could be control arm bushings. However, it could be sway bar bushings, ball joints, shock bushings...
I recommend that you closely check for these possible items because the control arm bushings are a pain to replace, and you don't want to do them unless you have to.
Feb 24, 2009 at 12:42 AM
