1994 Dodge Ram noisy stearing and suspention
53,000 MILES • V8 • 2WD • AUTOMATIC
AIRFORCEFANN
Hi, everytime I turn or run over a bump my truck, it starts to squeak. I greased up everything with a plugin nipple for the grease gun but still didn't help at all. Do i need to get new bushings and if I do where and also how many bushings. I have run out of ideas!!!!
Nov 30, 2007 at 11:16 AM
MERLIN2021
  • 17,250 POSTS
How old are the shocks? lets go basic first, look at the upper control ares, there is one bushing on each end of the arm, 2 bushings, when they are bad you can usually see the rubber oozing out fof the end, cut up...same on the lowers, if you think those are the problem, try spraying some WD-40 into them, soak em good, then bounce the truck, any difference?
Nov 30, 2007 at 12:32 PM
