Engine Mechanical problem
1994 Dodge Ram V8 Two Wheel Drive Automatic
I have a 1994 dodge ram I need to put an oil pump on it but dont know how or where it is and ont want to take to a shop.
Thursday, March 19th, 2009 AT 12:28 PM
DOCFIXIT
MECHANIC
Must remove oil pan it is mounted to crank craddle. Why do you need the pump?
SPONSORED LINKS
Thursday, March 19th, 2009 AT 2:04 PM
BEAR2104
MEMBER
I am buying it and the man was coming back from missippi to alabama and he was about an hour out and his oil p ressure dropped. So just from what I grew up around I guessed it was the oil pump and I might need a whole new motor just dont know yet but we will c.
Thursday, March 19th, 2009 AT 4:04 PM
DOCFIXIT
MECHANIC
Most likely rod bearings are shot oil pumps seldom fail
Thursday, March 19th, 2009 AT 5:10 PM
BEAR2104
MEMBER
How much will that cost do you suppose? Just for parts?
Friday, March 20th, 2009 AT 12:49 AM
DOCFIXIT
MECHANIC
If crank is in good shape @$45 for bearings so with pan off you can drop crank mains rotate top half out and replace. Then pull cover off pump measure gap between pump gears if more than.015 replace.
SPONSORED LINKS
Friday, March 20th, 2009 AT 3:29 PM
BEAR2104
MEMBER
Ok What will that be called doing and Could you possibly give me instructions of how to do it. I am trin to conserv money and me doing it myself will certainly help. If you can I will greatly appreciate it. Thanks in advance.
