1994 Dodge Ram
WARDEN60
  • 1994 DODGE RAM
Air Conditioning problem
1994 Dodge Ram V8 Two Wheel Drive Automatic
I can only get air out of my defrost vents. I have checked for a vacuum leake, and found none. Any suggestions as to what might cause this problem?
Tuesday, August 3rd, 2010 AT 2:57 PM
  • 109,868 POSTS
Are you getting vacuum to the controler?
Friday, August 6th, 2010 AT 12:11 AM
WARDEN60
Where is this controller you refer to located?
Friday, August 6th, 2010 AT 8:46 AM
  • 109,868 POSTS
I'm sorry. It is the one on the dash that you adjust air flow from. It has vacuum lines running to it and based on what position you have it set on, it directs the air to that place.
Saturday, August 7th, 2010 AT 12:05 AM
