1989 Dodge Ram
1989 DODGE RAM
10,000 MILES • V8 • 2WD • AUTOMATIC
ONEFATHERSLOVE
  • 10 POSTS
My vehicle has an early morning(cold engine) knocking sound. When I first start it, the knock begins, and if I press the accelerator the knocking will diminish. Once the vehicle warms up, then the knocking goes away. If I wait until about 9am when the sun has warmed it up a little then there is no knocking when I start it. Before I start taking things apart and replacing unnecessary items, can someone identify the problem and solution?
Thank you
Aug 30, 2009 at 3:12 AM
JDL
  • 16,098 POSTS
I'd try to pinpoint the knock, my hearing is no good, sometimes I use a long shank screwdriver, place the tip against the valve cover, the other end of the shank goes on that bone behind my ear. It seems to magnify the sound, sometimes I can locate where the sounds is coming from before taking anything apart.
Aug 30, 2009 at 3:58 AM
ONEFATHERSLOVE
  • 10 POSTS
Thank you for your reply. As you have indicated, the first and obvious thing to do is locate where the knock is comming from.
Aug 30, 2009 at 4:28 AM
