1987 Dodge Ram Gears wont engage
188,000 MILES • 4 CYL • FWD • MANUAL
BOBBI
Hi
I have a dodge ram 50 2.0 single barrel
We just put in a new clutch kit and it wont go into gear at all
The clerk at Nappa told us to use 5 w 30 motor oil instead of gear oil and I am wondering if maybe it is to thin for shifting or I do need the gear oil
I can't afford another car as I am on disability which don't pay
any ideas as to what is wrong with it
I also switch it from a 5 spd to a 4 spd
The clutch coverwas not the same as the other coverwould that make a diffrence?
I wish I could pay for the info
Nov 27, 2008 at 4:41 AM
  • 31,937 POSTS
Hi there,
Is the clutch throwing? when you press on the clutch pedal is the clutch fork moving, if so can you tell how far, if you put it in gear and start it with the clutch in, will it drive off?
Mark (mhpautos)
Nov 27, 2008 at 8:20 AM
BOBBI
Hey so sorry My comp is acting up and me being sort of a comp virgin took forever to fix it.
I really appreciate the help
the spline is shorter on one of the clutches
He says it will go in all gears except for reverse
You guy's really don't know how much I appreciate this And I do
When I can I WILL SEND IN A DONATION
Thanks again
Bobbi Fav're
I am also a mechanic virgin to some extent lol!!!!
Dec 5, 2008 at 2:18 PM
  • 31,937 POSTS
HI there,
I don't quite understand what this means...the spline is shorter on one of the clutches ..... i would be concerned that the clutch presser plate is your main concern, if the fingers are not at the same height as the old clutch, you will not be getting the through required.
Mark (mhpautos)
Dec 5, 2008 at 5:25 PM
