1989 Dodge B250 Engine Shuts Off
Well, it could have just got a bad signal from the distributor, and shut off. All you have ia a Single Module Engine Controller, ignition coil, and distributor. I would think if the coil went bad, it would stay bad. the distributor sends the signal to the controller for crankshaft and camshaft positions. An interuption of that signal could cause it you malfunction. I read that if the SMEC does not see a valid signal for 2 seconds from the distributor, it will activate the auto shut down which kills power to the coil and fuel pump. Might be the place to start your trouble shooting.
I would also think if the SMEC was overheating, it wouldnt just start right back up.
Suggested Repair
Start by checking the distributor pickup signal to the SMEC. A brief loss of a valid distributor signal can trigger auto shutdown and cut power to the coil and fuel pump, then allow a normal restart. A failed coil would more likely stay failed, and SMEC overheating is less likely if it restarts immediately.
Conversation Summary
A 1989 Dodge B250 with a 318 engine shut off while driving in hot weather, then restarted immediately with no further symptoms. Recent ignition and filter service had been done; the coil had not been replaced, and no condenser was found on the coil. The expert said the system uses a SMEC, coil, and distributor, and that a lost distributor signal for about two seconds can activate auto shutdown and kill power to the coil and fuel pump. That signal path was recommended as the starting point; a coil that failed would likely stay failed, and an overheating SMEC would be less likely to restart right away.
