2004 Dodge Minivan
2004 DODGE
NASIOM
The engine stalls after fueling. What is the problem or problems?
May 15, 2007 at 3:47 AM
ROAMING1
  • 9 POSTS
believe it or not i ran into a similar problem once and in my instance it was a suprisingly simple answer. make sure that you are turning the fuel filler cap so that it is clicking at least 3 times.
failure to do this sometimes results in a reduced fuel tank pressure..
sounds pretty corny but it is a standard instuctional on a lot of the newer imports. (it was resulting in an increase in service due to check engine codes)
May 15, 2007 at 1:02 PM
