2003 Other Dodge Models
2003 DODGE
BMWSTEVE
2003 Other Dodge Models 4 cyl 80000 miles
how do you bleed brakes rear brakes i never have
Dec 19, 2008 at 11:26 AM
  • 110,236 POSTS
Hi:
You will need a helper. Have the helper pump the brakes 5 or 6 times. Have him keep pressure on the brake pedal. Open the bleeder on the wheel cylender and air / fluid will be released as the pedal goes to the floor. Tell the helper to hold the brake down until you have tightened the bleeder. repeat this until no air comes out.
Start from the passanger side rear. Also, make sure the master cylender doesn't run empty on fluid.
Mar 14, 2009 at 10:58 AM
