2002 Other Dodge Models 5.9 diesel intake heater
2002 DODGE
MRRUBEN
Computer problem
2002 Other Dodge Models 6 cyl Two Wheel Drive Automatic 54k miles
my 2002 diesel does not start on its own i have to spray starting fluid to start it. intake heater does not get any power.
Feb 20, 2009 at 1:59 PM
DR LOOT
  • 2,311 POSTS
the intake heater only supplies warm air after the truck has been started, it is connect through the glow plug relay, most likely you had some burned-out glow plug which will not send power to the intake heater and the starting fluid did not help, using starting fluid on a glow plug system will most definitely burn out the glow plugs, check and replace the burned-out glow plugs and then check and see if you have power to the intake heater.
Feb 28, 2009 at 3:47 PM
