2000 Other Dodge Models oil pressure
2000 DODGE
JAYSGURL62000
2000 Other Dodge Models V8 Two Wheel Drive Automatic
what does oil sending unit do what is its job?
Jan 25, 2010 at 10:21 PM
HMAC300
  • 48,601 POSTS
the sending unit is an electrical switch that when pressure is put on it it closes and the electricity sent to it is modified tooperate the guage on our dash. If it works correctly it will tell you about how much oil pressure your engine is making while running. the same goes for the coolant sensor on ly tells temp and fuel leve indicator.only it tells level of fuel in the tanks.
Feb 13, 2010 at 12:58 AM
