1996 Other Dodge Models interior lights
1996 DODGE
160,000 MILES • V8 • 2WD • AUTOMATIC
PAULSAN
my interior light do not work--- and when i shut my truck off my raidio reset it shelf--it a 1996 dodge van 1500
Aug 30, 2008 at 2:03 AM
  • 110,240 POSTS
Hi:
I'm going to assume you checked the interior bulbs and the fuse. First, check if there is power to the light socket. If not, you will need to the remove the switch from the door frame. Check if there is power to the switch. If there is, replace the switch. If not, you will need to trace the power wire back until you find the problem.
If you have any other questions, let me know.
Oct 9, 2008 at 2:52 PM
