1989 Other Dodge Models won't shut off
1989 DODGE
128,000 MILES • V8 • 2WD • AUTOMATIC
JERAUS
When the key is turned off, the engine keeps running. Disconnecting the battery does not shut off the vehicle, I have to disconnect the coil wire to be able to shut off the truck.
1989 Dodge Ram Charger
Dec 8, 2007 at 9:08 AM
SADAMS2
  • 17 POSTS
I also have this problem with my 1998 Dodge Ram 1500. Does anyone have a solution?
Nov 3, 2008 at 9:28 AM
Disconecting the battery will shutdown the ignition system-for that to happen the engine has to be super hot to ignite the fuel left in the chamber that will cause pre-ignition and detonation.
Probable causes: Ignition timing off and a high curb idle speed.
Nov 3, 2008 at 9:40 AM
SADAMS2
  • 17 POSTS
This is not an engine run-on issue such as you are describing. Turning the key to the off position has no effect on the running engine. I have to pull the engine control fuse from the main fuse block under the hood to kill the engine. Why would the key not be shutting the engine off?
Nov 3, 2008 at 12:35 PM
You have an internal problem with the ignition switch
Nov 3, 2008 at 2:46 PM
SADAMS2
  • 17 POSTS
I have replaced the ignition switch. It did not help.
Nov 4, 2008 at 11:54 AM
What model Dodge is this?
Disconnecting the battery does not shut off the vehicle, I have to disconnect the coil wire to be able to shut off the truck. When you did this, was the engine running?
If not the switch could be the ignition circuit is shorted to the battery feed going to the ignition switch this the only way for this to happen the wires in the harness could be touching
Nov 4, 2008 at 12:22 PM
SADAMS2
  • 17 POSTS
98 Dodge Ram 1500
In my case I have to pull the Engine Control 2 fuse from the main fuse box under the hood to kill the engine. yes it it running when I pull the fuse.
Nov 4, 2008 at 1:19 PM
With the key off check for power at the coil positive terminal dark green and orange wire-Do you have power
Nov 5, 2008 at 5:38 AM
SADAMS2
  • 17 POSTS
I'll check this out and get back to you.
Nov 6, 2008 at 11:58 AM
SADAMS2
  • 17 POSTS
With the key in the off position, there was no power to the positive side of the coil. By the way, there was also no power to the positive side of the coil with the key in the on position either as far as I could tell.
Nov 9, 2008 at 7:14 AM
