1985 Other Dodge Models "sagging"
1985 DODGE
153,000 MILES • 4 CYL • FWD • AUTOMATIC
THESHADOW66
Hello, I have a 1985 Dodge 600 Convertible. Whenever an average weighed person (i.e. 140lbs, give or take) sits in the back or when I load the trunk up with anything heavy the back side of the car sags down significantly. Then when I drive at high speeds (i.e. 40+ in this case) and if I hit a bump something scratches BADLY because of the sagging. What is it that is causing this? and how much would it cost to fix?
Oct 13, 2008 at 10:38 AM
  • 110,244 POSTS
Hi:
I believe you have struts on the rear of that car. If so, you need to purchase a heavy duty coil spring for the strut assembly. The orig ones were not that strong when they were new, and over the years they just got worse.
Mar 20, 2009 at 9:57 AM
