At the age of the van, has your timming chain ever been replaced? Do a quick compression test, if you don't have a tester, pull a plug I do #1, put your finger over the plug hole, not in it, over it and crank, should be sufficient pressure to blow air forcefully past your finger. Make sure timming in cap matches #1 cyl!
SPONSORED LINKS
Saturday, September 29th, 2007 AT 8:43 AM
