1990 Dodge Omni instrument cluster
1990 DODGE OMNI
60,400 MILES • 4 CYL • 2WD • AUTOMATIC
PEEP0529
the odometer stopped working and I was advised to replace the cluster, which is electric not cable. When I rec'd the new (used) cluster and I was garunteed it was a working unit. When installed it did the same thing. The odometer was the only thing not working the speedometer is fine. Do you think the new (used) is bad as well or is there something else wrong?
Dec 9, 2009 at 1:58 PM
CH112063
  • 1,320 POSTS
If the odometer still does not work it most likely is bad luck. You can still get key codes very well, but I can't see anything except if there is any speed sensor that was sometimes used in a cable. It led to nowhere. Or there is a signal missing from the speed sensor ref. It would be a code 15 if I'm not mistaken. Good luck, let me know if you can. Didn't see many 90's. Great car. I wish I had one. you may pull a code that shows somewhere to start, is the replaced speedometer also a no cable? if yes, see if the key on, off, on, off, on--- flashes anything. Sorry I can't be of more help.
Dec 15, 2009 at 3:22 PM
