1996 Dodge Neon Overheating
DLIGHTHART
1996 Dodge Neon , 55,000 miles. Well the car is still overheating and we have put a radiator, thermostat, and coolant sensor in it. We tested the fans with a 12v battery and they were running but I am just not sure with the car running. I think we heard them come on when we were stopped but after driving the car for 35 minutes, it overheated. Then it would go down some, then the temp guage would go back up. What do we do now?? Help!!!!
Aug 16, 2006 at 1:44 PM
MIKEYBDMAN
  • 623 POSTS
[quote:a0acfeb57a="dlighthart"]1996 Dodge Neon , 55,000 miles. Well the car is still overheating and we have put a radiator, thermostat, and coolant sensor in it. We tested the fans with a 12v battery and they were running but I am just not sure with the car running. I think we heard them come on when we were stopped but after driving the car for 35 minutes, it overheated. Then it would go down some, then the temp guage would go back up. What do we do now?? Help!!!![/quote:a0acfeb57a]
You need to visually look at the fans when the car is running hot. You need to know if the fans are running to figure out the problem. If the fans are running, and it is hot, it may be the water pump if you havent tried that.
If not the fan or pump, it sounds as if you have an obstruction not allowing the coolant to flow. Check for kinked hoses, or collapsed hoses.
Aug 16, 2006 at 2:58 PM
Suggested Repair
Visually confirm the cooling fans run when the engine is hot. If they do, check the water pump. If the fans and pump are not the cause, look for restricted coolant flow from kinked or collapsed hoses.
Conversation Summary
A 1996 Dodge Neon with 55,000 miles still overheats after a radiator, thermostat, and coolant sensor were replaced. The fans ran when powered by a 12-volt battery, but it was unclear whether they ran with the engine operating; after about 35 minutes of driving the temperature rose, dropped somewhat, then rose again. The expert advised watching the fans while the car is hot, then checking the water pump if the fans are running, and inspecting for kinked or collapsed hoses if coolant flow is obstructed.
