Neon Running ROUGH!
BUCKEYESUAVE
  • DODGE NEON
I have a 95 Dodge Neon two years ago I replaced the head gasket, Timing belt, Water pump and the Car has been fine until a few months ago when it started running VERY rough but only sometimes, Other times it runs fine. I ran the codes and it showed single or multiple cylinder misfire and Injector circuit error, I replaced the injectors and checked all the wiring and the harness and it stil does it sometimes, It loses power and Misses very bady but probably just 20% of the time or less. I am not losing any fluids and it is NOT running hot. Could it be the computer? If so can I have the memory flashed into my computer or do I have buy another one? The car is still under 100K miles.
Thanks
Sunday, March 5th, 2006 AT 12:51 PM
TLSEAL
My car, 2000 dodge neon 84,000 miles, does the same thing. I've changed the gas (thought maybe I had some bad gas), the plugs, wires, and coil. I didn't change the fuel pump yet, but that is where I'm heading.
If anyone has any ideas, I'd appreciate it as well!
Monday, March 5th, 2007 AT 11:01 AM
BMOHR225
Does it accelerate rough? If you could specify when it acts up it might help diagnose.
Wednesday, April 27th, 2011 AT 7:24 PM
