2004 Dodge Neon Idle Irregularity
2004 DODGE NEON
77,800 MILES • 4 CYL • FWD • AUTOMATIC
KIT0825
I've been troubleshooting this problem for 4 months now, I've checked the fuses for shorts disabled numerous systems, and have come up empty handed. I've also changed out my TPS, and IAC motor. The only mod I've put on the vehicle so far is a K&N air filter. The problem is everything runs perfect unless I'm pulling up to a red light. While I'm slowing down my idle flucuates until I come to a stop and then it gradually drops down to 500. At this time the entire car shakes just enough to notice a difference. In the same situation if I repeat these steps while I'm in neutral everything runs perfectly. There is no check engine light or indicators of vaccum leaks. Therefore the only time the problem shows up is when the vehicle is in drive. Do you have any other suggestions?
May 20, 2008 at 4:32 PM
BMRFIXIT
  • CAR REPAIR CONTRIBUTOR
  • 19,053 POSTS
we had an issue like this
we replaced the spark plugs and ignition wires and had the PCM flashed
problem solved
I would say 90 % it the PCM software
May 22, 2008 at 5:37 PM
KIT0825
I have actually replaced the spark plugs and wires just a few months ago actually. So where do I need to go to get the PCM reprogrammed or something of the sort to finally solve this issue. And thanks by the way for the guidance.
May 23, 2008 at 4:23 PM
BMRFIXIT
  • 19,053 POSTS
have your VIN # ready and call the local dodge dealer
May 23, 2008 at 5:04 PM
