2004 Dodge Neon
85,000 MILES • 4 CYL • FWD • AUTOMATIC
JASON2004NEON
hi, hope u can help...car makes a vibration noise when driving forward..only goes away when turning left but not right...thanks for a reply, jay
Nov 18, 2009 at 6:44 PM
SERVICE WRITER
  • 9,123 POSTS
First thought is a wheel bearing issue. What speeds does that happen at?
Nov 18, 2009 at 9:42 PM
JASON2004NEON
HI...from a slow start to any speed it makes the noise...when i go around a left turn it goes away...but not a right turn or when driving straight
Nov 20, 2009 at 4:25 AM
SERVICE WRITER
  • 9,123 POSTS
IF it sounds like a roar, then it is probably a wheel bearing gone bad. Check for play in any of the wheels.
Nov 20, 2009 at 4:56 AM
JASON2004NEON
Yes it is a roaring sound...recently rotated tires and did actually check for any play and seemed tight...should i go ahead and replace them anyways?
Nov 20, 2009 at 4:58 AM
SERVICE WRITER
  • 9,123 POSTS
No, you need to determine which one is bad.
There may be play now as the pitting will continue to get worse. Generally you can tell which side it is coming from, if you can, then yes replace that bearing, if not you need to verify it....or risk replacing the wrong one.
You can verify it with a set of chassis ears.
You can also verify it if it is in the front by raising the front end in a safe manner, putting it in drive and comparing the two sides with a stethescope.
Nov 20, 2009 at 6:31 PM
