4 Quarts should be fine. You must use Chysler atf +4 tranny fluid. IF you used regular dextron then you need to get an additive. Lube gard make a product that will convert the fluid. It comes in a black 10 oz. Bottle and it take one ounce per quart.
Check the level when it's hot with the engine running.
SPONSORED LINKS
Thursday, April 10th, 2008 AT 6:21 AM
