I have changed the idle air control valve, the throttle position sensor and the MAP sensor with no luck. Still is running at about 9 thousand rpms as soon as the motor starts. I rented a computer and it is giving the codes for the 3 things I have changed already. So I erased the codes and tried again. Still giving the code for the MAP sensor. What should I do? Does any body have any idea what might be causing this?
Saturday, June 26th, 2010 AT 9:38 AM
